Redirect issue
Thread begun 1/07/2011 8:23 am by twitchr377598 | Last modified 1/07/2011 12:55 pm by Jason Byrnes | 3111 views | 4 replies |
twitchr377598
Redirect issue
I'm using an html editor on a form that is on an update page. Everything was working fine then all of a sudden I'm getting a weird redirection.
For instance, in the update code the redirect is set like:
$WA_redirectURL = "index.php";
Instead of getting:
index.php
I'm getting something like below on redirect:
index.php
Not sure if this is a problem with the DataAssist files or the HTML editor files. It seems it happened right after I used the upload image feature in the HTML editor. The image shows up properly on the page after edit and all edits are saved, but when I go back to the update page, the image shows up as a question mark.
Thanks in advance,
Twitch
are you using data assist 2.0.8?
if so see this post for a fix.
showthread.php?t=17866
twitchr377598
BINGO! That was it.
Thanks for the quick reply Jason.
-Twitch
twitchr377598
PS you guys need a solved button on these forums. ;-)
glad to hear it worked.
