Warning: mysql_query(): supplied argument is not a valid MySQL-Link
Thread begun 1/06/2011 8:18 pm by gpaul | Last modified 1/07/2011 12:17 pm by Jason Byrnes | 7282 views | 7 replies |
gpaul
I am receiving this error message when trying to connect to a database.
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/90/7253390/html/WA_SecurityAssist/Helper_PHP.php on line 14
Same error for line 20.
Those lines are (14)
mysql_select_db($WA_Auth_Parameter["database"], $WA_Auth_Parameter["connection"]);
$WA_Auth_loginSQL = "SELECT `".implode('`,`', $WA_Auth_Parameter["sessionColumns"])."` FROM `".$WA_Auth_Parameter["tableName"]."` WHERE ";
And (20)
$WA_Auth_RS = mysql_query($WA_Auth_loginSQL, $WA_Auth_Parameter["connection"]) or die(mysql_error());
It is a little perplexing in that I have another site up and the code is the same and I have no connection problems.
Anyone be able to point me to my problem?
Thank you
Gary
please send a copy of the login page in a zip archive.
gpaul
Thank you, find attached.
Gary
the connection file on your page is:
<?php require_once('Connections/rr.php');?>
but the login code is looking for a connection named login.php
gpaul
Eric
Thank your for your quick reply, however there is no login.php on that page. There is
"connection" => $login,
Is that what you are referring to?
Thanks again.
yes, that is the problem.
the connection file will create a variable based on the name of the file.
the Connections/rr.php file creates a variable named $rr
the Connections/login.php would create the variable named $login
the authenticate user code was created using the Connections/login.php connection file, but that connection is not present on the page.
gpaul
Problem Solved
Thanks again for your help, problem has been solved.
Gary
you're welcome.
