install online
Thread begun 1/06/2011 11:42 am by bobquigley419054 | Last modified 1/06/2011 1:12 pm by Jason Byrnes | 2891 views | 5 replies |
bobquigley419054
install online
I've uploaded Powercms to www.stjohnevan.com. Everything seems to look proper, so I call up index.php.. no problem. The server checks out and as soon as I go to the next stage (install) I get this error message: Framework file not found: ../Templates/install.dwt.php. Everything stalls right there. I have to dump out of Firefox because it freezes.
Any help would be appreciated
make sure that the Templates directory of the power cms files has been uploaded to you server, i can get to the install script at your link, but trying to access the templates directory gives a 404 error, meaning it has not been uploaded.
bobquigley419054
Installation online
If you mean the Templates directory under WA_Globals. It was uploaded and reloaded a minute ago
there should not be a templates directory inside the wa_globals directory.
the templates directory should be at the root of the power cms folder.
bobquigley419054
Installation online
That is where is was located in the file I downloaded originally from your site. Perhaps it unzipped wrong. In any event, I have at least relocated the templates directory on my website server to the root of Powercms. I will attempt install from there. thanks.
OK, let us know if you need further assistance.
