Sort Order incorrect
Thread begun 1/06/2011 7:48 am by christina.elissa4324782 | Last modified 1/06/2011 10:07 am by Jason Byrnes | 4637 views | 11 replies |
I'm attempting to sort columns using the Sorting by Column Link recipe solution. I am trying to sort 3 columns; by id, lastName, registered (date).
The id and registered appear to be sorting correctly. however the last name column is not sorting correctly; it's not alphabetical.
This is a results page and I am using pagination; showing 15 records at a time.
Can you tell me if I'm doing something incorrect?
Thank you in advance
Christina
the code looks correct.
to see the query that is being generated, add the following code after the body tag:
<?php echo($query_limit_WADAattendee); ?>
can you provide a link where i can see the problem to investigate further?
Here is what was returned on the page:
SELECT attendeeId, salutation, firstName, middleInitial, lastName, rankService, positionTitle, company, street, street2, city, stateCountry, postalCode, phoneNumber, faxNumber, email, payBy, paid, paymentReceiptEmailed, badgeNameTitle, DATE_FORMAT(registered, '%m-%d') AS registered FROM attendee ORDER BY attendeeId DESC, lastName ASC, registered DESC LIMIT 0, 10
admin/
The current login info is below
here is the search page so that you can get to the results page
i'm getting the following error when i try to test your page:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'OREDER BY lastName, firstName LIMIT 0, 10' at line 1
it looks like you added an order by clause manually ut have misspelled ORDER as OREDER
I'm not getting that error. What page did you test?
I found where that was, and fixed it. It was in the DefaultSort in the DataAssist Sort. I put that there trying to get it to do it by default.
The problem is still there.
In the Sorting section, you have only added the static column names. the first item should be the sort query string.
Click the button to add a new sort option. Next to column, click the lightning bolt and expand the Querystring Data binding group, select the sort querystring. Make sure this is first in the list.
Now I'm getting a MySQL error:
Warning: sprintf() [function.sprintf]: Too few arguments in /home/ifpaor5/public_html/ifpafletcherconference.com/2011/admin/attendee_Results.php on line 162
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ORDER BY attendeeId ASC, attendeeId ASC, lastName ASC, registered DESC LIMIT 0,' at line 1
Here is the Sort code:
//WA DataAssist Sort (Copyright 2007, WebAssist.com)
//Recordset: WADAattendee;
$WADA_Sort_1 = new WADA_SortObject();
$WADA_Sort_1->DefaultSort = "";
$WADA_Sort_1->ColumnList = "".((isset($_GET["sort"]))?$_GET["sort"]:"") ."^attendeeId^lastName^registered";
$WADA_Sort_1->SortOrderList = "Ascending^Ascending^Ascending^Descending";
$WADA_Sort_1->ToggleOn = true;
if ((((isset($_GET["sort"]))?$_GET["sort"]:"") != "")) {
$WADA_Sort_1->SetToClause = $WADA_Sort_1->getDefaultSetToClause();
if ($WADA_Sort_1->ToggleOn && isset($_SESSION["WADA_OrderClause_attendee_Results"])) {
$WADA_Sort_1->ToggleClause = $_SESSION["WADA_OrderClause_attendee_Results"];
else if (isset($_SESSION["WADA_OrderClause_attendee_Results"])) {
$WADA_Sort_1->SetToClause = $_SESSION["WADA_OrderClause_attendee_Results"];
$WADA_Sort_1->initialize();
$_SESSION["WADA_OrderClause_attendee_Results"] = $WADA_Sort_1->SetToClause;
I tried again having to copy and past my mysql select query because editing the sort server behavior deleted most of it when I edited it. Things appear to be working now.
Thank you.
Christina
ok, glad to hear it is working.
Now, I'm noticing that the date is not ordered correctly. I have it based on a column that converts the date to a Unix Timestamp. It's showing Dec 2010, Nov 2010, Jan 2011 when it should be Nov 2010, Dec 2010, Jan 2011.
Wouldn't a unix timestamp be the best way to sort a date on?
