Problem with Boss
Thread begun 1/06/2011 7:31 am by rico-m345501 | Last modified 1/07/2011 10:33 am by Jason Byrnes | 11445 views | 25 replies |
rico-m345501
Problem with Boss
Hello,
I have a problem with search for boss. I follow the steps in the tutorial, and then comes the following error message:
Parse error: syntax error, unexpected '}' in /mnt/weba/30/30/5593230/htdocs/fotos/results.php on line 69
Here can you see:
results.php
how can I solve the problem?
please send a copy of your page so i can examine the code.
rico-m345501
This is the Code from results.php
if ("".($Search1_BOSS_all) ."" > "0") { // WebAssist Show If
<div>Viewing records <?php echo($Search1_BOSS_start); ?> to <?php echo($Search1_BOSS_end); ?> of <?php echo($Search1_BOSS_all); ?></div>
<div>
if ("".($Search1_BOSS_start) ."" != "1") { // WebAssist Show If
<a href="<?php echo(getBOSSURL("Search1","first")); ?>">&lt;&lt;</a> <a href="<?php echo(getBOSSURL("Search1","previous")); ?>">&lt;</a>
} // ("".($Search1_BOSS_start) ."" != "1")
if ("".($Search1_BOSS_end) ."" != "".($Search1_BOSS_all) ."") { // WebAssist Show If
<a href="<?php echo(getBOSSURL("Search1","next")); ?>">&gt;</a> <a href="<?php echo(getBOSSURL("Search1","last")); ?>">&gt;&gt;</a>
} // ("".($Search1_BOSS_end) ."" != "".($Search1_BOSS_all) ."")
</div>
} // ("".($Search1_BOSS_all) ."" > "0")
if ("".($Search1_BOSS_all) ."" == "0") { // WebAssist Show If
<div>No results found matching your search.</div>
} // ("".($Search1_BOSS_all) ."" == "0")
<?php require_once("Yahoo/BOSS_include.php"); ?>
$Search1_BOSS_page_size = 10;
$Search1_BOSS_appID = "KwAW.dfV34FRo8WDt.sKj0tjyuLNnGRKH0Eclarc2bnBaAjvQWXz988wadpjWbxZFXcY";
$Search1_BOSS_domain = "http://lenkercrew.de/";
$Search1_BOSS_result = "";
$Search1_BOSS_start = 0;
$Search1_BOSS_end = 0;
$Search1_BOSS_all = 0;
$Search1_BOSS_index = 0;
$Search1_BOSS_term = "";
if($Search1_BOSS_page_size > 50) {
$Search1_BOSS_page_size = 50;
if(isset($_GET['Search1_BOSS_start']) && preg_match("/[0-9]+/",$_GET['Search1_BOSS_start'])) {
$Search1_BOSS_start = $_GET['Search1_BOSS_start'];
if ("bold" != "") {
$Search1_BOSS_term = "bold";
$word = "/^[a-z|A-Z|0-9| |-|\"]+$/";
if(!preg_match($word,$Search1_BOSS_term)) {
$_SESSION['Search1_BOSS_term'] = $Search1_BOSS_term;
} else if (isset($_SESSION['Search1_BOSS_term']) && $_SESSION['Search1_BOSS_term'] != "") {
$Search1_BOSS_term = $_SESSION['Search1_BOSS_term'];
if ($Search1_BOSS_term != "") {
$Search1_BOSS_result = getBOSSResults($Search1_BOSS_term, $Search1_BOSS_start, $Search1_BOSS_appID, $Search1_BOSS_domain, $Search1_BOSS_page_size);
if (!empty($Search1_BOSS_result)) {
$Search1_BOSS_feed = new SimpleXMLElement($Search1_BOSS_result); // convert the XML string into ab object structure
$Search1_BOSS_all = $Search1_BOSS_feed->resultset_web['totalhits']; // get the amount of results
if ($Search1_BOSS_all > 1000) $Search1_BOSS_all = 1000;
$Search1_BOSS_start = $Search1_BOSS_feed->resultset_web['start'];
$Search1_BOSS_end = ($Search1_BOSS_all > $Search1_BOSS_start+$Search1_BOSS_page_size) ? $Search1_BOSS_start+$Search1_BOSS_page_size : $Search1_BOSS_all;
if ($Search1_BOSS_end!=0) $Search1_BOSS_start = $Search1_BOSS_start+1;
} else {
while ($Search1_BOSS_index <= ($Search1_BOSS_end - $Search1_BOSS_start ) && $Search1_BOSS_end != 0) {
<div>
<h3><a href="<?php echo(getBOSSValue($Search1_BOSS_feed,$Search1_BOSS_index,"result url")); ?>"><?php echo(getBOSSValue($Search1_BOSS_feed,$Search1_BOSS_index,"title")); ?></a></h3>
<div><?php echo(getBOSSValue($Search1_BOSS_feed,$Search1_BOSS_index,"abstract")); ?></div>
<?php echo(getBOSSValue($Search1_BOSS_feed,$Search1_BOSS_index,"keywords")); ?> </div>
$Search1_BOSS_index ++;
please send the php page in a zip archive so i can open it in dreamweaver to navigate to line 69 where the error is occurring.
rico-m345501
Error Message
here is the file...
it looks like some code was deleted from the page.
The code causing the error is lines 68 - 70:
the error is occurring because the corresponding opening if statement was removed. add this if statement before the opening body tag:
rico-m345501
the code is on line 1-3. I dont understand.
it is not in the file you sent me. the code from the body tag that you sent to me is:
<body>
<div>
it should be:
<body>
<div>
when i edited the page you sent me to include that code, it worked.
rico-m345501
The file in the Zip archive is also on the server, nevertheless, there comes the same error message.
the file in the zip archive has the following at line 50 - 52:
<body>
<div>
it needs to be changed to:
<body>
<div>
as suggested previously.
