users_profile.php problem
Thread begun 1/05/2011 10:48 am by bchilds | Last modified 1/06/2011 9:32 am by Jason Byrnes | 2799 views | 7 replies |
bchilds
I am having a slight problem with my users_profile.php page.
When i click the verify email button, it just goes to a blank white page.
Otherwise page works fine.
Powerstore 2.
Page attached.
Thanks in advance,
BChilds
PS Looked in db and email verification is still 0
the verify button on the profile page does not effect the database, it sends an email with a link that when clicked will update the database.
a blank page means that a php error has occurred, but error reporting is turned off.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
bchilds
I got the message:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/t/a/c/tacmedso/html/store/users_Profile.php:5) in /home/content/t/a/c/tacmedso/html/store/WA_eCart/WA_eCart_Definition_PHP.php on line 479
that error occurs if there is a blank space between php code blocks
most likely the issue is a blank space at line 4 when you added the error reporting code:
make sure there is not a trailing space after the closing php tag.
bchilds
Once again Jason,
You da man!
Thanks so much!
BChilds
So is it working now then?
bchilds
Yes. Thanks again.
Bhilds
ok glad to hear it is working.
