No Payment Gateway confirm order page problem
Thread begun 1/04/2011 7:05 pm by nancy268153 | Last modified 1/05/2011 12:53 pm by Jason Byrnes | 3943 views | 9 replies |
nancy268153
No Payment Gateway checkout failure
Using Powerstore 3 and None for Payment Gateway. I intend to email or call for payment info at a later date / custom orders.
all works well until I hit the "Submit Order" button on the confirm.php page.
Here is what happens wrong:
1) the order being entered in the database but it is replacing the last test order. ie. there is still only 1 order in the database no matter how many test orders I try to do. the order in the database always matches the most recent test order
2) I do NOT get taken to the checkout_success.php page. it's just reloading the same "confirm.php" page.
3) the item(s) are still in the shopping cart.
how do I fix it?
thanks Nancy
points 1 and 3 are a result of point 2. the cart gets cleared when you get to the success page. the order id also gets reset so the next order will create a new record.
most likely there is a php error occurring that is preventing the redirect to the success page.
add the following code at line one of the confirm page to turn error reporting on:
error_reporting
(E_ALL);
nancy268153
thanks, I added the code to the very beginning (line 1) of the confirm.php and uploaded it. tried another order and got the same result.
Was this supposed to show the error on the confirm.php page on the site after trying to order? if so, it did not work.
confused???
Help
If an error is occurring that code should show the error.
if it is not showing an error, there are 2 possibilities:
1) I was wrong initially, and the problem is not caused by a php error
2) the server is configured to not allow error reporting to be turned on using ini_set.
I'm going to assume it is possibility 1, wouldn't be the first time i guessed wrong, and it certainly wont be the last.
If it's not a php error, my next guess is that the server does not have the $_SERVER["HTTP_REFERER"] variable enabled.
try changing the following code at line 1091 - 1093:
else if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))  {
  $WA_Store_Cart->redirStr = "checkout_success.php";
else if (isset($_POST["Submit_order"]))  {
nancy268153
sorry, still nothing.
I made another little change on the page to the heading just to be sure I was fixing the correct page and it was getting uploaded and it showed up. so, I know I am changing the right page and getting it up to the server with the changes but still nothing that we have tried yet has worked.
still with me? I hope. I appreciate your patience.
BTW, should I change back those things above that we have tried and did not work?
create a new php page with the following code in it:
<?php phpinfo(); ?>
upload it to the server and send a link.
Also send a copy of your confirm page so I can look at the code.
nancy268153
OK, wow, thanks for staying with me. so good to get this done all at once.
here is the new test page URL:
test.php
I am also attaching a copy of confirm.php with the changes that you have suggested intact.
ok, try changing line 1238 - 1244:
// WA eCart Redirect
if ($WA_Store_Cart->redirStr != "")     {
    unset(
$_SESSION['randomConfirm']);
header("Location: ".$WA_Store_Cart->redirStr);
<?php if($GLOBALS['WAGLOBAL_Gateway'] == && isset($_POST["Submit_order"]))  {
$WA_Store_Cart->redirStr "checkout_success.php"
    unset(
nancy268153
well thank you :) that has it working as far as I can see.
should I leave the other/previous changes or switch them back?
hooray! thank you so much.
great, glad to hear it is working, you can switch the other changes back.
