data not send in emails for mailinglist
Thread begun 1/04/2011 9:07 am by jpbosboom.60369949 | Last modified 1/05/2011 11:39 am by Jason Byrnes | 3112 views | 6 replies |
jpbosboom.60369949
working with cs4 or CS 5 and UE3.07 or 4.0 on windows 7
We use to send emails with recordset data out on mailinglists etc which worked fine fill update to CS5 and UA4.0. After removing 4.0 and installing again 3.07 still got problems.
The message i get : applyServerBehaviour in WA Universal Email javascript error. I removed the .dat files.
Hope someone has the solution.
UE3 is not compatible with DWCS5, you will need to use UE4 in DWCS5.
in the email body code, edit the code that references the recordset:
<?php echo $row_RsName['ColumnName']; ?>
<?php echo $RecipArray[$RecipIndex][0]['ColumnName']; ?>
jpbosboom.60369949
tried what you wrote but mail does not loop. Only first record has been sent.
if (!isset($_SESSION))session_start();
if ((!($totalRows_rs_beurs == 0))) {
//WA Universal Email object="mail"
should be sending 4 recors for a test.
Any futher info.
Does webassist solve this issue in an update shortly?
please send a copy of your page in a zip archive so I can look at the code.
jpbosboom.60369949
data not send in email for mailing list
pls see attached the zip file
jpbosboom.60369949
again the zip files
