warnings with UE4
Thread begun 1/03/2011 12:56 pm by wanakavideo420554 | Last modified 1/03/2011 1:22 pm by Jason Byrnes | 1338 views | 1 replies |
wanakavideo420554
warnings with UE4
I get following warnigs when I run the script in the browser:
<br />
<b>Warning</b>: session_start(): open(/tmp\sess_3999a8b9dea12ab511e84688fd4ff55d, O_RDWR) failed: No such file or directory (2) in <b>c:\program files\server\apache\www\weddingvideonz\contact.php</b> on line <b>4</b><br />
<br />
<b>Warning</b>: session_start(): Cannot send session cookie - headers already sent by (output started at c:\program files\server\apache\www\weddingvideonz\contact.php:4) in <b>c:\program files\server\apache\www\weddingvideonz\contact.php</b> on line <b>4</b><br />
<br />
<b>Warning</b>: session_start(): Cannot send session cache limiter - headers already sent (output started at c:\program files\server\apache\www\weddingvideonz\contact.php:4) in <b>c:\program files\server\apache\www\weddingvideonz\contact.php</b> on line <b>4</b><br />
<br />
<b>Warning</b>: Unknown(): open(/tmp\sess_3999a8b9dea12ab511e84688fd4ff55d, O_RDWR) failed: No such file or directory (2) in <b>Unknown</b> on line <b>0</b><br />
<br />
<b>Warning</b>: Unknown(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/tmp) in <b>Unknown</b> on line <b>0</b><br />
I attached the web-page-code as txt
these errors mean that there a configuration issue with session management on the hosts server, you will need to contact the host to have the issue resolved.
most likely the session.save_path in the php.ini file on the server is pointing to a location that does not exist, but the host will need to investigate this.
