UE issues
Thread begun 1/03/2011 12:01 pm by rob293221 | Last modified 1/10/2011 9:48 am by Jason Byrnes | 5100 views | 10 replies |
rob293221
UE issues
Hello,
I am having some problems getting a few bugs worked out. Any help would be appreciated. Thanks in advance!
Issue #1.
Attachments are not working. I have set this up exactly as I have on previous sites, and this one doesn't want to work. webcam.php
Issue #2
One the same form, the FROM filed will not work. When the email comes thru, the field is blank. Majority of the time causes it to go to my junk folder.
Issue #3
If the captcha code is entered incorrectly, most of the time it wipes out all information that has been entered into the form. Is there a way to prevent this so that the information will not have to be reentered?
Thanks again,
Rob
1-2) What version of Universal Email are you using? Can you send a copy of your page and the webassist directory so i can look at the code.
looking at the source of the page, you have form elements that are using a space in the name:
<input type="text" size="60" id="Email Address" name="Email Address">
this is not valid, form element names cannot contain spaces.
3) In the bindings panel, there is a binding group name Validated Entities. This group contains the valid posted values.
Set the initial value for each form element to use the corresponding binding from the validated entries collection.
rob293221
Files are attached.
rob293221
I am using UE4
these two form elements are out side of the form:
<input name="addblock" type="text" id="addblock" style="display:none" value="" />
<input name="seconddblock" id="seconddblock" type="text" style="display:none" value="" />
move them so they are after the form tag.
the attachment code looks correct, I dont see anything in the code that is preventing the attachments.
to debug, change the following line:
$GoToPage = "webcam_thankyou.php";
$GoToPage = "";
and add this code at line 1:
error_reporting
(E_ALL);
ini_set('display_errrors','on');
what size are the images you are uploading? try with very small images to see if that works, it may be that the image size is causing the upload to fail.
rob293221
I am lost when it comes to the Binding Panel that you mentioned. Can you explain what I am supposed to do there. Thanks!
Select each form element in design view.
in the Property inspector, click the lightning bolt next to Initial Value
In the dynamic data bindings window that opens, expand the Validated Entries group and select the corresponding binding for that form element.
for select lists, you will need to click on the Dynamic button in the property inspector, and click the lightning bolt next to Select Value Equal To. Again, expand the Validated Entries collection, and select the corresponding binding.
rob293221
My Validated Entries selection doesn't expand. It has an image of a red dotted square with a check mark and says WA Validated Entries (webcam.php).
The items that are expandable are webcam_app, Server Variables, Universal Email 1 (mail)
have you tried deleting the Dreamweaver cache file from the users configuration folder:
Have you fixed the issues with the form element names containing spaces? You will need to fix that problem before anything else.
can you send the most recent copy of your page so i can examine the code
rob293221
Newest files attached. Thanks!
