Possible Bug Form Toolkit & Library Items
Thread begun 1/03/2011 10:27 am by jcav26033 | Last modified 1/03/2011 10:27 am by jcav26033 | 1147 views | 0 replies |
jcav26033
I have to say "Thank You" for Form Toolkit. Once you learn how to use it, it is really a great extension.
That said, I have two pages that contain library items (a navigation and a music player) in two different locations on the page. When I try to apply the server "show if" behavior I get an error message that "This would require changes to code locked by a template and will not be applied" (slight paraphrase). I delete the library items then it works and I re-insert them when done. The page is not templated, just has library items, but it seems that the toolkit should be able to get around this common page construction without having to delete the library items...has anyone else experienced this? Should it be added to the developer's bug list for the next release?
Update: I see that the template issue has been solved in a previous post (temporarily remove the template flag code in code view) but this is a bit different since there are no template regions, only library files.
