Slow response from PowerCMS script
Thread begun 1/02/2011 7:36 am by dennis.zervas308099 | Last modified 1/03/2011 8:30 am by Ray Borduin | 10753 views | 1 replies |
dennis.zervas308099
Dear team,
I am experiencing very slow response when using the PowerCMS 102 script on a web site.
I have different installations for different customers on the same web host:
One is admin which loads fine
The one under question is the admin which takes ages to load, but will eventually load. I think I have this on either 100 or 101.
If you login (feel free, login is giannousi, password is lina128), then again it will work but it takes ages to proceed and all clicks you do will be very slow. This is on PowerCMS 102.
If you check the php page that shows the text which the PowerCMS manages, it loads ok:
news_dual.php
I am trying to locate the problem, is it with the script or with the web host?
Thanks for your help
Dennis Zervas
For me, even the page you say loads fine loads very slowly. In fact it is still loading as I'm responding. My best guess is that it is a fundamental problem with the connection to the database on your server, but the only way to know for sure is to debug it.
I'd create a blank page with some simple text... see how long that takes to load... Then add a database connection (maybe just the connection include with no actual recordset) and see how much that slows it down. Then add a recordset that returns a row from the contents recordset. See if you can narrow down what exactly is causing the slowdown and then you will have a clue where to start when trying to speed it up.
Something is definitely wrong, but it is impossible to say what exactly without some debugging.
Another debug technique you can try is adding this to the first line of the code on a slow page:
<?php echo(date('h:i:s') . "<BR>"); ?>
then add it a little lower on the page... then you can compare the two to see how much time has passed between those lines of code. By moving it around you should be able to narrow down where exactly the slowdown occurs.
