Problem with UPS ecart
Thread begun 6/21/2009 8:22 pm by jreshard228604 | Last modified 6/22/2009 6:50 am by Ray Borduin | 2360 views | 1 replies |
jreshard228604
I am having a problem with ecart and ups. I have 4 different products, users can select as many asthey want of each product, but I am shipping in one box. I have a shipping table keyed by the number of items with length, width, height, and weght. I am trying to use the total quantity session variable to select the recordset from the shipping table. If I hard code the the number instead of using the session variable I can get the ups return but using the session variable nothing it fails. I have been working on this for a long, long, long time. Any help would be appreciated
I think I understand what you are describing, but I would need more details or to look at the code to possibly help. From what you are describing it seems possible and it seems you are trying to do it correctly. You are clearly making a mistake somewhere, but without debugging it is hard to tell where.
Are you getting the correct results from your recordset? Is the session variable stored correctly when you display it on the page? You need to narrow down exactly where your problem originates in order to solve it.
