Loss of 'synch' between visible theme and PS setting theme settings
Thread begun 1/01/2011 5:30 am by msummers194171 | Last modified 1/05/2011 5:45 am by msummers194171 | 2015 views | 2 replies |
msummers194171
I have been editing a theme (admittedly mostly by direct access of files rather than through the control panel), and up until yesterday, the control panel showed my selected theme properly. Now, however, when I go to the Design section of the control panel, it shows that the Current Theme is "Crazy", and the them I have been working on appears to be deselected. What would I need to do to get this display back into synch?
what happens if you reselect the theme you working on as the currant theme in the admin panel? reelecting it should rest it as the current theme.
msummers194171
Thanks, Jason. I'll try that and let you know. Was worried that this might mess with some other changes I had made.
