2 datepickers wouldn't work on 1 form
Thread begun 12/31/2010 9:18 am by russ278131 | Last modified 1/04/2011 10:18 am by Jason Byrnes | 2400 views | 3 replies |
russ278131
I added 2 date pickers to a form, and only the 1st time I clicked in one of the date fields would the date picker pop up. It would never show up again.
I resolved this by going to the jquery home page, and updated the jquery from 1.3.2 to 1.4.4, and the jquery ui from 1.7.1 to 1.8.7. It took a little editing, but now it works.
Please update jquery and jquery ui in CSS Form Builder.
I just created a test page using two date pickers, and was not able to reproduce the problem, both date pickers where working without an issue without having to update the jquery and jquery UI files.
can you send a link showing the issue so i can look into the cause.
MikeyT
just a thought...
Since the jQuery libraries version updates can potentially be more frequent than Form Builder updates, to keep the javascript libraries current one thought is to strip out the jQuery and jQuery UI library files that Form Builder implements and link directly to Google's Library API. You can even link to the minified versions for production.
I have entered a feature request for this to be considered.
