Installing PowerStore on local wamp server
Thread begun 12/30/2010 3:12 pm by locaulker43514 | Last modified 1/03/2011 9:12 am by Jason Byrnes | 2038 views | 1 replies |
locaulker43514
I get the following message when installing PowerStore4.0.1 on my local wamp server:
"Failed to save the settings in the database. Please verify your database connection"
I have checked the connection script. Seemed to be right but I still get the error message. What I'm I doing wrong or what is the cause of the repeated problem?
the error pretty mush means that the connection script is not correct.
if you are installing on a local server, the MySQL server should be "localhost", the user name should be "root"
I believe that the default password for MySQL in is a blank value. but you should change it using the Wamp Admin panel.
