show only records not present in another table
Thread begun 12/30/2010 1:53 pm by CraigR | Last modified 12/30/2010 3:01 pm by CraigR | 1965 views | 2 replies |
CraigRBeta Tester
I have a list of events to which members can be invited
the table structure is as follows..
tblevent
eventid(PK)
eventname
...etc
tblmember
memberid(PK)
membername
...etc
tbleventmember
eventmemberid(PK)
eventid
memberid
tbleventmember is my many-to-many table which allows any number of members to be at each event.
i have an 'add multiple members to an event page', which inserts rows to tbleventmember.
this works fine.
at present, the datasource for the add multiple page is simply tblmember
i would like to change this, so that for a specific eventid, my list shows only members in tblmember whose id is not present in tbleventmember.
can anyone suggest the simplest way of achieving this ?
you would need to use a compound select statement:
SELECT * FROM tblmember WHERE tblmember.memberid IN (SELECT tbleventmember.memberid FROM tbleventmember WHERE tbleventmember.memberid != 2)
By using the IN key work, the first query is using the result set from the second query as it's source.
CraigRBeta Tester
Great.
That's what I needed.
I managed it easily in the MSAccess GUI, but couldn't work it in MySQL,
Thanks again
