Powerstore 4 Gallery
Thread begun 12/30/2010 12:52 pm by rob294118 | Last modified 1/03/2011 10:56 am by Jason Byrnes | 4354 views | 9 replies |
rob294118
When I add a gallery to the Store Message section, the width is extended and makes the formatting wrong. How can I fix this?
Example: www.getfitlookgreat.com/
in the galleries/slideshow_wide/index.php file, change:
$gallery = get_gallery(get_mediarss_url('gallery=' . $pg_id . '&thumb=62c&full=995c'));
$gallery = get_gallery(get_mediarss_url('gallery=' . $pg_id . '&thumb=62c&full=782p'));
rob294118
That made it worse. It's too small now.
the available gallery widths are:
proportional:
1024px
782px
163px
cropped:
62px
132px
102px
42px
782px
995px
if you wanted to create a custom width, you would need to edit the admin/common/properties.php file.
see the following power gallery thread for details:
showthread.php?t=10969
rob294118
Why wouldn't the default work? I didn't change anything. I just added the slideshow gallery. The default 995c should work without me having to fix anything.
your site design is not 995px wide, it is 960px wide.
default_styles.css
#outerWrapper {
margin:0 auto;
padding:0 10px;
width:960px;
rob294118
I just changed it to 995px but it didn't fix anything.
just changing the width of the outer wrapper wont change the width of the elements within the outerwrapper, that's why oi did not suggest it as a fix.
rob294118
I don't know how to fix this. I used the defaults and just added a gallery. It doesn't format right. I just want to know how to fix it. I'm not very happy with PowerStore 4.
you need to edit the line in the index file to use a smaller gallery size:
if 782px is too small, you will need to edit the admin/common/properties.php file to define a new galley size.
