Logo Image Padding
Thread begun 12/30/2010 7:14 am by KiddaMan | Last modified 12/30/2010 10:07 am by Jason Byrnes | 4629 views | 8 replies |
KiddaMan
Logo Image Padding
Hello,
Please take a look at the attached file.
1) I am trying to get the logo image to pull down to the menu bar. I have used firebug to find the div's but cant seem to make it happen. Can you help here ?
2) I would like to put some image mapping into my header image and I can generally do this in the admin section; however, the logo is now added into the design section by uploading and does not give an option to enter code. Where is the code for the header logo for me to enter my image mapping code ?
Thanks So Much !
1) Please provide a link where i can examine the css to help with the positioning issue.
2) The logo image is applied as a background image using CSS. you can not apply an image map to a css background image.
KiddaMan
1) Luxehats.com
2) Its there a way for me to not use the image background and insert code into the header area.
in webassist/themes/Luxehats/css/default_home.css change:
#outerWrapper #navWrapper {
height:auto;
padding: 7px 0 0;
height:auto;
padding: 0;
in webassist/themes/Luxehats/css/default_styles.css change:
#outerWrapper #navWrapper #aboveNavigation {
background:url("../images/topNavigation_above.png") no-repeat scroll 0 0 transparent;
height:12px;
width:100%;
height:0;
width:100%;
and change:
#header {
#header {
max-height: 92px;
2) Sorry, i misspoke, the logo image is added as an image tag, you can add the image map code in the webassist/themes/Luxehats/templates/page.dwt.php and webassist/themes/Luxehats/templates/index.dwt.php
KiddaMan
Your are the man ! Thanks for taking the time to help. I will apply the changes and let you know.
Also, just wanted you to know, and for what its worth, that I sent an email to WebAssist, mentioning your unbelievable help over the past few weeks/months...Thanks !
KiddaMan
Jason,
All worked great, for the home page ! Thanks
Take a look at the other menu pages,(i.e. Product, Support, Contact Us, etc.) how can I remove the small space on those ?
change:
clear:both;
margin:0;
padding:7px 0 20px;
clear:both;
margin:0;
padding:0 0 20px;
KiddaMan
Beautiful piece of work my friend.
For your following instructions:
Do I need to apply the imaging mapping code at both .php locations ?
Let me know if you need a hat !
yes, the page.dwt.php file is the template for the site pages, the index.dwt.php file is the template for the index page.
