JS Error when trying to add field validation
Thread begun 12/29/2010 2:16 pm by dianaringer276728 | Last modified 3/02/2011 8:14 am by Ray Borduin | 2212 views | 3 replies |
dianaringer276728
Just installed CSS Form Builder today -- but when I try to add a "required" client-side validation to a field I get the following error:
"While executing onLoad in WAFV_Required_C.htm, the following javascript error occurred ... At line 14 of file [path]WAFV_Required_C; isThisACommand is not defined."
Having a similar problem with the Alphanumeric validation as well.
Thanks in advance.
Di
I've created a support incident so that we can look into this issue with you directly.
debbie295402
Has this been resolved? I am getting the same error using CSS Form builder 2.0 and DataAssist 2.0. Thanks.
To fix that issue i attached a file that fixes that issue. Please replace your current shared.js file with the attache file at this location:
Configuration/Shared/WebAssist/FormBuilder
Make sure Dreamweaver is closed and delete the cache file before restarting.
