History not working
Thread begun 12/29/2010 8:26 am by chris373619 | Last modified 12/29/2010 1:17 pm by chris373619 | 6118 views | 18 replies |
chris373619
History not working
I get this error page when I try to use the history page. I tried replacing the page but that doesn't help. Can you help?
This is what I get:
Manage Users | Advanced Search | Log Out
Warning: require_once(../../CSSMenuWriter/cssmw/menu.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/18/6226118/html/cms/admin/contenthistory_results.php on line 191
Fatal error: require_once() [function.require]: Failed opening required '../../CSSMenuWriter/cssmw/menu.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/18/6226118/html/cms/admin/contenthistory_results.php on line 191
what is on line: 191 of the file:
is the file:
/home/content/18/6226118/html/CSSMenuWriter/cssmw/menu.php
uploaded and in that location?
chris373619
this is what's on line 191.
<?php require_once("../../CSSMenuWriter/cssmw/menu.php"); ?>
is the file:
The error implies that file doesn't exist? does it have a different name? Is that the wrong path to the file?
chris373619
It seems like the correct path. I have attached a picture.
actually it looks wrong.... I think it should only have one ../
Try updating that line to have only one ../
chris373619
How does that happen???? That part of the code is locked and not editable. Is it part of a template. Should I detach from template to edit this line of code?
Not sure... I think it does come from a template, but that depends on what version you are using. What version of powercms do you have installed?
chris373619
I think 2.01 but I'm not for sure about that.
