Update Page
Thread begun 12/28/2010 5:41 pm by davidp420108 | Last modified 12/29/2010 7:31 am by Ray Borduin | 1386 views | 1 replies |
davidp420108
Update Page
I have built a series of pages with DA and they all work great. The thing I would like to fix though is it doesn't auto populate the input file fields.
I am uploading images and if there are 10 photos on a page, and if I only want to change one, I have to re-enter or upload all of them or it leaves a null value (or something) and removes the prior uploaded files, leaving me with only the "new" uploaded files.
I have searched the forums and found others with this problem, but no explanation on how to solve it, that I understand.
On a normal input text field, it is easy enough to default-dynamically assign a value to it (with the init val field in properties), but I don't see that option on the "file field" input.
Is this something DA can assist with or do I need to code it. Directions for either would be much appreciated.
This is some code a hacked at:
<input type="file" name="Photo_10_File" id="Photo_10_File" value="<?php echo(str_replace('"', '&quot;', $row_WADAinventory_tbl['Photo_10'])); ?>" size="32" />
If there is a better way, I would love to hear that.
Thanks in advance...
You can't set the value of a file field in html for security reasons so that you can't take files from someone from a hidden file field on a form, so that technique won't work.
What you can do, is populate an image field above or beside your file field, or put the value to the left or right of the file field.
Then in the file upload server behaviors (you would use one per upload field), you would specify the default value of the upload to be equal to the field in the database associated with that photo.
The input file field stays blank, but they can see if there is an image or what the image is by adding a thumbnail of the image beside it. Then if they don't specify a value, it stays blank, and dataAssist will use the default value for the image, which is the original value from the updated recordset (what you currently are trying to set to the value of the file field, should be the default value of the upload server behavior).
