Power store 401 SKU = Product Name
Thread begun 12/28/2010 12:28 pm by Daniel69688 | Last modified 12/28/2010 1:53 pm by Ray Borduin | 2468 views | 3 replies |
Daniel69688Beta Tester
Why is it that the Product SKU field is set to equal the Product Name field in the database and there is no form field in the admin section for editing the product SKU?
The form field for editing the SKU should be on the "Additional Settings" tab when inserting or updating a product.
Thanks Ray
Thanks Ray!
As I delve into the cart functionality to gain familiarity with it, is there a commented version or a programmers reference available?
I will need to be able to make changes without pondering some of the syntax and complex code you have in the power store.
-Daniel
There is no programmers reference currently available. You can use this forum to find questions and answers from people that have asked similar questions, or post questions here when you have them.
Ecart functions are contained in the WA_eCart folder in the file named after the shopping cart, and the definition file. The function names are pretty self explanitory if you are a programmer and look through those two files. Much of the functionality can be accessed through server behaviors and bindings if you own eCart.
