results page help
Thread begun 12/28/2010 12:18 pm by davidp420108 | Last modified 12/29/2010 8:09 am by davidp420108 | 3731 views | 17 replies |
davidp420108
results page help
On my results page I am getting several inches of space before the first record of the repeating region is displayed. I cannot find any breaks in the code, but i am new to php and data assist.
The page was built with the wizard and works fine if i don't apply a template. but if i build the page using a template and an editable region, it has several inches of empty space before the first result. I am using the word inches because I don't believe there are "lines" of anything, just a gap
I would appreciate a suggestion, all result pages are doing this.
thanks.
davidp420108
here is the file...
This would be easier to debug if you provided a url so we could see the problem in the browser. Do you have a url where we can view this issue in order to help debug it?
davidp420108
access_Results.php
davidp420108
sorry trying to get it "live" but not having success. New to mysql/php/dataassist
davidp420108
I uploaded the page but it is displaying "blank". I did not move the database "live" yet. (don't know how)
access_Results.php
here is the php info page my web host setup to see if there is a setting not working
phpinfo.php
HELP!
The page is giving a 404 error, so it means that page isn't uploaded to that directory.
Check to make sure the file was properly uploaded.
davidp420108
I do not see that error. In Firefox a blank page loads. In IE8 it says that the page may be under maintenance or has programming error.
Please bear with me. I am a noob on this software, but have successfully made several other sites.
I now see a blank page, maybe you were in the middle of uploading it.
Try adding this to the top of the page:
<?php ini_set('display_errors', 1); ?>
davidp420108
Did it. The error seems to be that the database isn't live.
Do I need to make it live to load the page. it is currently on the testing server only. I would have thought the page would load with no data, but maybe that is the problem?
thanks again
David
