UE 4 error message
Thread begun 12/28/2010 11:26 am by cbright420341 | Last modified 12/29/2010 12:23 pm by cbright420341 | 3858 views | 6 replies |
cbright420341
UE 4 error message
I just bought Universal Email 4 and I'm trying to test it for use in a very simple procedure: just a form that can be used to email a mailing address.
I made a very simple test form and ran the UE 4 Create Email Message as described in the Getting Started Guide. I entered the minimum number of variables there and uploaded the resulting php page to a test section of our web site.
But the results won't load in a browser. Instead I see this message:
Warning: require_once(../../webassist/email/mail_php.php) [function.require-once]: failed to open stream: No such file or directory in /data/13/1/146/2/1309165/user/1401962/htdocs/es2/act/mail/formtest.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../webassist/email/mail_php.php' (include_path='.:/usr/services/vux/lib/php') in /data/13/1/146/2/1309165/user/1401962/htdocs/es2/act/mail/formtest.php on line 1
What am I doing wrong? I'm not used to this yet it's probably something obvious!
Best,
Chris
Try uploading the entire /webassist/ folder again. It sounds like a file may not have been properly uploaded to the server.
cbright420341
A little farther along
Ray, thanks for the advice! That worked--or at least it got me to the next step. My test form now sends an email but the email doesn't include the form content. It's just blank.
I've made test form as simple as possible--it just contains one text field and a submit button--so there probably aren't too many variables in play. What do you think I'm doing wrong now?
Chris
What is the form method set to? Do you have a sample url? What are you using as your body? Did you use one of the default email templates?
cbright420341
Sorry to have been so vague. My form method is set to POST.
Here's the url of the page that contains my current test:
formtest3.php
I have tried a couple of different things for the body--all of them pretty inept, I'm sure. All I really want is for the contents of my "test" field to show up there. I'm not trying to create any special formatting. In my current test, I tried to achieve this with a "post" command. You can see that from the following lines, which I've pasted in from the relevant webassist waue file:
//Start Mail Body
$MailBody = $MailBody . "<html><head></head><body>";
$_POST["test"];
$MailBody = $MailBody . "</body></html>";
//End Mail Body
Thanks for looking this over.
Chris
$MailBody = $MailBody . $_POST["test"];
cbright420341
Perfect! Thanks a lot!
