recordset error
Thread begun 12/27/2010 12:49 pm by serhat_alpaslan | Last modified 1/30/2011 12:56 pm by Brad Lawryk | 3027 views | 5 replies |
serhat_alpaslan
recordset error
i saved the pluggings that i prepared into this file
..i got a file called plugins.these pluggings are running properly there seems to be no issue (problem).Despite that when i use these pluggings with framework builder, warning and exclamation mark appears in recordsets.Although i made some researches about the issue i couldnt find a clear explanation i would be happy for the assistance
There are three pieces to every recordset.... the connection file, the recordset code, and the close recordset code placed on the bottom of the page.
The exclamation point implies that one of these is incorrect.
serhat_alpaslan
these are all correct, but there are still warning
You could double-click to open it and then click 'ok' that should force DW to resolve any issues. Then check the code in code view and see If it duplicates some code then you know that is the code it didn't like for some reason, but you could probably just ignore it.
davidp420108
Hope this helps - it helped me.
I found this thread that should solve your problems.
showthread.php?t=15711&highlight=underscore+naming+convention
Brad Lawryk
I found its best to ignore the exclamation mark, especially if you are not familiar with code. In my experience when opening and saving the recordset in DW it sometimes creates duplicate code but places it before the old code.
While the mark may or may not dissapear having the code there and duplicated has usually caused more errors - like duplicate closing of the connections.
Ignore the mark - I have never had an issue that way.
Brad
