Universal Email 4.0.1 troubles...
Thread begun 12/27/2010 10:23 am by fdotmedia | Last modified 12/27/2010 11:56 am by fdotmedia | 1964 views | 4 replies |
fdotmedia
I want to email a form including 10 questions, via radio button, and a name field to myself...
I get the form to redirect correctly, from form.php to thanks.php, but I'm not receiving an email... I believe I have the widget setup properly...
BTW, I am using php and have all the necessary files uploaded as well...
Any help would be great...
Thanks,
Ted
Did you specify a SMTP server, 99% of the time you can leave that setting blank.
If you are going to the thank you page it means it is probably trying to send the email.
You can add this code to the thank you page:
@session_start();
var_dump($_SESSION);
The dump will include information about the email including any errors that could have occrred.
fdotmedia
I still don't see any incoming emails... I added the mail details...
I don't see any errors... Do you?
array(10) { ["waue_quiz_1_Total"]=> int(0) ["waue_quiz_1_Index"]=> int(0) ["waue_quiz_1_Remaining"]=> int(0) ["waue_quiz_1_Log"]=> string(55) "Sending To: tmoore@changecompanies.net... Success
" ["waue_quiz_1_From"]=> string(0) "" ["waue_quiz_1_To"]=> string(26) "tmoore@changecompanies.net" ["waue_quiz_1_Subject"]=> string(26) "New Mexico Quiz Submission" ["waue_quiz_1_Body"]=> string(536) " --WAMULTIBREAKWA Content-Type: text/plain Content-Transfer-Encoding: 8bit ted has submitted a New Mexico DWI quiz. question 1: 1a question 2: 2a question 3: 3a question 4: 4a question 5: 5a question 6: 6a question 7: 7a question 8: 8a question 9: 9a question 10: 9a --WAMULTIBREAKWA Content-Type: text/html ted has submitted a New Mexico DWI quiz. question 1: 1a question 2: 2a question 3: 3a question 4: 4a question 5: 5a question 6: 6a question 7: 7a question 8: 8a question 9: 9a question 10: 9a --WAMULTIBREAKWA-- " ["waue_quiz_1_Header"]=> string(240) "MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="WAMULTIBREAKWA" From: Reply-To: Return-Path: X-Sender: X-Priority: 1 Date: Mon, 27 Dec 2010 11:32:00 -0800 (PST) Message-ID: <786314023.d41d8cd98f00b204e9800998ecf8427e@> " ["waue_quiz_1_Status"]=> string(7) "Success" }
There are no errors.
You should be getting that email to: tmoore@changecompanies.net
You can see the status: ["waue_quiz_1_Status"]=> string(7) "Success"
This means it sent the email message and recieved no errors from the email server. This means that the smtp server is erroring and you may need to check their error logs, or your email is getting caught by spam filters and is actually being sent, but you aren't able to recieve it because of some email filters.
fdotmedia
Thanks Ray! I'll track it down from here...
