Registration Form resets in Browser rather than showing "Thank You" Page
Thread begun 12/27/2010 8:01 am by greg419490 | Last modified 12/27/2010 1:57 pm by greg419490 | 6223 views | 13 replies |
greg419490
Hello,
After filling out my "Registration Form" in browser, and clicking Submit, the form "resets" and includes most of my information, but I have to re-enter passwords, and Captcha and challenge question.
This continues (looks like form moves a little each time, and never reveals the "Thank You for Registering" page. And of course, database is not accessed.
Below is the link to the page.
users_Registration.php
Any help will be very much appreciated!
Greg
It is probably an issue with the server validation.
Can you .zip a copy of the page and attach it? Or just copy and paste the server validation code from the top of the page.
greg419490
Registation Page Not Working
Hello Ray,
I've attached a zip file of the "UserRegistration" folder.
Hope this helps.
Thanks!
Greg
Well I don't see any issues offhand...
Try addding code to the body of the page
var_dump($_SESSION);
That will allow you to see what validation is failing specifically, which could help narrow it down anyway.
greg419490
Error
Thanks,
Here's the error:
array(1) { ["random_answer"]=> int(48) }
I want to see what it says after submitting the page. It appears you didn't leave the code up so I could test and see what I could find.
greg419490
Try this...
Here's the link...page is on server:
It appears you have removed the country field from the form, but left the server validaiton on the php page.
Remove this line from the code:
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserCountry"]))?$_POST["UserCountry"]:"") . "",true,19);
greg419490
Yes, I did...from the form. I also removed the "Fax No." from the form. I presume I also left the validation for the fax too?
This makes sense. I'll remove the validation for country and check if the Fax Val. is also hanging around.
Cool...
greg419490
This error is left after submit:
Unknown column 'UserFax' in 'field list'
I tried to take out the validation, but that didn't get rid of the error.
