adding Menu image
Thread begun 12/26/2010 4:44 pm by Larry321390 | Last modified 12/27/2010 10:01 am by Ray Borduin | 1678 views | 1 replies |
Larry321390
adding Menu image
I have several questions about changing the store menu to match my menu,
products_results.php
I’m trying to use my images for the menu and have several questions as to where I find things.
From other posts I have modified menu.php. and design in admin. However, I can not locate the files forthe following.
!. Where do I modify the buttons:
Support,
Log In,
Register?
2. Half the menu bar turned gray like I want but where do I turn the other half gray.
3. Where do I change the rollover color from black to another color?
Hope you had a nice holiday.
Thanks,
Larry
The support link and its can be edited from the CMS section of the admin.
The login and register links are edited from:
webassist/plugins/headerlinks/headerlinks.php
I'd suggest downloading and using firebug to help determine what .css needs to be changed. Most will be located in the folder webassist/Themes/[YourThemeName]/CSS
Firebug will be a great resource to determine where and what to update.
