Install Problems
Thread begun 12/22/2010 5:39 pm by rich.johnson0706369868 | Last modified 12/28/2010 2:24 pm by Jenny I | 2423 views | 4 replies |
Install Problems
When entering my serial number during the install I keep getting an error. I have copied the serial number from my web page account and that doesn't work. I have tried entering the serial number manually, which requires that each form field be entered from right to left. Still no luck.
Dani Chankhour
what error are you getting?
Jenny I
I am having the exact same problem
  Fatal error: Call to undefined function curl_init() in C:\wamp\www\mysite\powercms\install_cms\serial.php on line 20
This error means that the CURL library is not installed on your server. You will have to contact your server support to get curl activated, or if you have access to your php.ini you can add it there manually.
Jenny I
Hi Ray
Sorry cURL was the problem, it has now been resolved.
