Injection Script?
Thread begun 12/22/2010 11:49 am by lbunnell124698 | Last modified 12/27/2010 11:45 am by Ray Borduin | 11674 views | 8 replies |
lbunnell124698
Injection Script?
I've been getting form responses all day with this in every field:
!S!WCRTESTINPUT000000!E!
I tried entering that myself on a page with WA Server Validation and it went right through regardless of which validation I tried to use. I even put !S!WCRTESTINPUT000000!E! in restrict content and it still went through.
Anyone else experienced this or, better, have a solution?
You could add captcha or security question validation to prevent bots from filling out your form.
You could use alphanumeric validation on that field which would prevent the "!"
lbunnell124698
That's what's so wierd. I actually have alphanumeric validation on the fields and for some reason it accepts that entry:
Can I see a sample of the form and validation code you are using? Is any of the validation working?
lbunnell124698
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?> <?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?> <?php if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos($_SERVER["HTTP_REFERER"], $_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"]) > 0) && isset($_POST)) { $WAFV_Redirect = ""; $_SESSION['WAVT_homealert_Errors'] = ""; if ($WAFV_Redirect == "") { $WAFV_Redirect = $_SERVER["PHP_SELF"]; } $WAFV_Errors = ""; $WAFV_Errors .= WAValidateRQ(((isset($_POST["fName"]))?$_POST["fName"]:"") . "",false,1); $WAFV_Errors .= WAValidateEM(((isset($_POST["email"]))?$_POST["email"]:"") . "",true,2); $WAFV_Errors .= WAValidateRQ(((isset($_POST["PriceRangeLower"]))?$_POST["PriceRangeLower"]:"") . "",false,3); $WAFV_Errors .= WAValidateRQ(((isset($_POST["PriceRangeUpper"]))?$_POST["PriceRangeUpper"]:"") . "",false,4); $WAFV_Errors .= WAValidateRQ(((isset($_POST["Area"]))?$_POST["Area"]:"") . "",false,6); $WAFV_Errors .= WAValidateRQ(((isset($_POST["lName"]))?$_POST["lName"]:"") . "",false,7); $WAFV_Errors .= WAValidatePN(((isset($_POST["DayPhone"]))?$_POST["DayPhone"]:"") . "",true,false,true,8); $WAFV_Errors .= WAValidateAN(((isset($_POST["fName"]))?$_POST["fName"]:"") . "",true,true,false,true,"",true,16); $WAFV_Errors .= WAValidateAN(((isset($_POST["lName"]))?$_POST["lName"]:"") . "",true,true,false,true,"",true,17);
if ($WAFV_Errors != "") { PostResult($WAFV_Redirect,$WAFV_Errors,"homealert"); } } ?> <?php if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos($_SERVER["HTTP_REFERER"], $_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"]) > 0) && isset($_POST)) { $WAFV_Redirect = ""; $_SESSION['WAVT_homealert_796_Errors'] = ""; if ($WAFV_Redirect == "") { $WAFV_Redirect = $_SERVER["PHP_SELF"]; } $WAFV_Errors = ""; $WAFV_Errors .= WAValidateLE($_SESSION['captcha_Security_Code_1'] . "",((isset($_POST["Security_Code_1"]))?$_POST["Security_Code_1"]:"") . "",true,15);
if ($WAFV_Errors != "") { PostResult($WAFV_Redirect,$WAFV_Errors,"homealert_796"); } } ?>
lbunnell124698
<?php if (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "" . ",") !== false || "" == "")){if (!(false)){ ?><p>We encountered errors in the form you submitted.</p> <?php }} }?><form method="post" action="" id="homealert" name="homealert"><input type=hidden name="subject" value="Email Update"><fieldset><legend>Contact Information </legend><div class="notes"><h4>MLS Email Updates </h4><p class="last"><strong>Bolded Fields are required.<br /></strong></p></div><div class="required"><label for="fName"><?phpif (ValidatedField("homealert","homealert")) {if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "1" . ",") !== false || "1" == "")){if (!(false)){?><?php }}}?>First Name: </label><inputname="fName" type="text" id="fName" value="<?php echo(ValidatedField("homealert","fName")) ?>"></div><div class="required"><label for="lName"><?phpif (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "7" . ",") !== false || "7" == "")){if (!(false)){?><?php // homealert(7:)}}}?> Last Name: </label><inputname="lName" type="text" id="lName" value="<?php echo(ValidatedField("homealert","lName")) ?>"></div><div class="required"><label for="phone"><?phpif (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "8" . ",") !== false || "8" == "")){if (!(false)){?><?php }}}?>Daytime Phone: </label><input name="DayPhone" type="text" value="<?php echo(ValidatedField("homealert","DayPhone")) ?>" maxlength=40><div class="small">Include Area Code </div></div><div class="optional"><label for="EveningPhone">Evening Phone:</label><inputname="EveningPhone" type="text" id="EveningPhone" value="<?php echo(ValidatedField("homealert","EveningPhone")) ?>"></div><div class="optional"><label for"fax">Fax: </label><input name="fax" type="text" id="fax" value="<?php echo(ValidatedField("homealert","fax")) ?>" maxlength=40></div><div class="required"><label for="email"><?phpif (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "2" . ",") !== false || "2" == "")){if (!(false)){?><?php // homealert(2:)}}}?> Email: </label><input name="email" type="text" size="45" id="email" value="<?php echo(ValidatedField("homealert","email")) ?>"/></div><div class="optional"><label for="Address">Address: </label> <input name="Address" type="text" id="Address" value="<?php echo(ValidatedField("homealert","Address")) ?>"></div><div class="optional"><label for"City">City: </label><input name="City" type="text" id="City" value="<?php echo(ValidatedField("homealert","City")) ?>"></div><div class="optional"><label for="State">State: </label><select name="State"> <option value=" " <?php if (!(strcmp(" ", (ValidatedField("homealert","State"))))) {echo "selected=\"selected\"";} ?>>Select</option> <?php do {?> <option value="<?php echo $row_rsState['code_sta']?>"<?php if (!(strcmp($row_rsState['code_sta'], (ValidatedField("homealert","State"))))) {echo "selected=\"selected\"";} ?>><?php echo $row_rsState['name_sta']?></option> <?php } while ($row_rsState = mysql_fetch_assoc($rsState));$rows = mysql_num_rows($rsState);if($rows > 0) { mysql_data_seek($rsState, 0);$row_rsState = mysql_fetch_assoc($rsState);} ?></select></div><div class="optional"><label for="Zip">Zip Code: </label> <input name="Zip" type="text" id="Zip" value="<?php echo(ValidatedField("homealert","Zip")) ?>"></div></fieldset><fieldset><legend>Property Information</legend><div class="required"><label for="searchState">State/Province</label><select name="searchState"><option value=" " <?php if (!(strcmp(" ", (ValidatedField("homealert","searchState"))))) {echo "selected=\"selected\"";} ?>>Select</option><?php do {?><option value="<?php echo $row_rsState['code_sta']?>"<?php if (!(strcmp($row_rsState['code_sta'], (ValidatedField("homealert","searchState"))))) {echo "selected=\"selected\"";} ?>><?php echo $row_rsState['name_sta']?></option><?php } while ($row_rsState = mysql_fetch_assoc($rsState));$rows = mysql_num_rows($rsState);if($rows > 0) { mysql_data_seek($rsState, 0);$row_rsState = mysql_fetch_assoc($rsState);} ?></select></div><div class="required"><label for="Area"> <?phpif (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "6" . ",") !== false || "6" == "")) {if (!(false)){?> <?php }}}?>Area: </label><textarea name="Area"><?php echo(ValidatedField("homealert","Area")) ?></textarea><div class="small">County or area of search. Required to set up email updates</div> </div><div class="required"> <label for="PriceRangeLower"><?php if (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "3" . ",") !== false || "3" == "")){if (!(false)){ ?><?php}} }?>Minimum Price:</label> <input name="PriceRangeLower" type="text" class="formtext" value="<?php echo(ValidatedField("homealert","PriceRangeLower")) ?>"/></div><div class="required"><label for="PriceRangeUpper"><?php if (ValidatedField("homealert","homealert")){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "4" . ",") !== false || "4" == "")){if (!(false)){ ?> <?php }}}?>
lbunnell124698
Maximum Price: </label> <input name="PriceRangeUpper" type="text" class="formtext" value="<?php echo(ValidatedField("homealert","PriceRangeUpper")) ?>"/></div><div class="optional"><label for="Bedrooms">Bedrooms:</label> <selectname="Bedrooms"><option value="2" <?php if (!(strcmp(2, (ValidatedField("homealert","Bedrooms"))))) {echo "SELECTED";} ?>>2</option><option value="3" selected <?php if (!(strcmp(3, (ValidatedField("homealert","Bedrooms"))))) {echo "SELECTED";} ?>>3</option><option value="4" <?php if (!(strcmp(4, (ValidatedField("homealert","Bedrooms"))))) {echo "SELECTED";} ?>>4</option><option value="5" <?php if (!(strcmp(5, (ValidatedField("homealert","Bedrooms"))))) {echo "SELECTED";} ?>>5</option><option value="5 or more" <?php if (!(strcmp("5 or more", (ValidatedField("homealert","Bedrooms"))))) {echo "SELECTED";} ?>>5 or more</option></select></div><div class="optional"><label for="Baths">Baths: </label><select class="formtext" name="Baths"> <option value="1" <?php if (!(strcmp(1, (ValidatedField("homealert","Baths"))))) {echo "SELECTED";} ?>>1</option> <option value="2" selected <?php if (!(strcmp(2, (ValidatedField("homealert","Baths"))))) {echo "SELECTED";} ?>>2</option> <option value="3" <?php if (!(strcmp(3, (ValidatedField("homealert","Baths"))))) {echo "SELECTED";} ?>>3</option> <option value="4 or more" <?php if (!(strcmp("4 or more", (ValidatedField("homealert","Baths"))))) {echo "SELECTED";} ?>>4 or more</option></select></div><div class="optional"><label for="zonearea">Zone: </label> <textarea name="zonearea"><?php echo(ValidatedField("homealert","zonearea")) ?></textarea> <small class="text"><br /> If known</small></div><div class="optional"><label for="Comments">Other criteria: </label><textarea name="Comments" ><?php echo(ValidatedField("homealert","Comments")) ?></textarea><div class="optional"><label for="timeframe">When do you plan on buying?</label> <selectname="timeframe"><option value="0-30 Days" selected <?php if (!(strcmp("0-30 Days", (ValidatedField("homealert","timeframe"))))) {echo "SELECTED";} ?>>0-30 Days</option><option value="0-60 Days" <?php if (!(strcmp("0-60 Days", (ValidatedField("homealert","timeframe"))))) {echo "SELECTED";} ?>>30-60 Days</option><option value="60-90 Days" <?php if (!(strcmp("60-90 Days", (ValidatedField("homealert","timeframe"))))) {echo "SELECTED";} ?>>60-90 Days</option><option value="3-6 Months" <?php if (!(strcmp("3-6 Months", (ValidatedField("homealert","timeframe"))))) {echo "SELECTED";} ?>>3-6 Months</option><option value="6 Months or more.." <?php if (!(strcmp("6 Months or more..", (ValidatedField("homealert","timeframe"))))) {echo "SELECTED";} ?>>6 Months or more..</option></select></div><div class="optional"><label for="HometoSell">Do you have a home to sell?</label><selectname="HometoSell"><option value="Yes" <?php if (!(strcmp("Yes", (ValidatedField("homealert","HometoSell"))))) {echo "SELECTED";} ?>>Yes</option><option value="No" selected <?php if (!(strcmp("No", (ValidatedField("homealert","HometoSell"))))) {echo "SELECTED";} ?>>No</option></select></div><div class="optional"><label for="Preapproval">Do you have a <a href="preapproval.php">Mortgage Pre-Approval</a> letter?</label> <selectname="Preapproval"><option value="Yes" <?php if (!(strcmp("Yes", (ValidatedField("homealert","Preapproval"))))) {echo "SELECTED";} ?>>Yes</option><option value="No" selected <?php if (!(strcmp("No", (ValidatedField("homealert","Preapproval"))))) {echo "SELECTED";} ?>>No</option></select></div><div class="optional"><label for="CurrentAgent">Do you have a current buyer agent?: </label> <selectname="CurrentAgent"><option value="Yes" <?php if (!(strcmp("Yes", (ValidatedField("homealert","CurrentAgent"))))) {echo "SELECTED";} ?>>Yes</option><option value="No" selected <?php if (!(strcmp("No", (ValidatedField("homealert","CurrentAgent"))))) {echo "SELECTED";} ?>>No</option></select></div><div class="optional"><label for="buyerRebate">Are you currently enrolled in the Buyer Rebate Program?: </label> <selectname="buyerRebate"><option value="Yes" <?php if (!(strcmp("Yes", (ValidatedField("homealert","buyerRebate"))))) {echo "SELECTED";} ?>>Yes</option><option value="No" selected <?php if (!(strcmp("No", (ValidatedField("homealert","buyerRebate"))))) {echo "SELECTED";} ?>>No</option></select></div><div class="required"> <img id="capt1" src="webassist/captcha/wavt_captchasecurityimages.php?width=200&height=50&field=Security_Code_1&bgcolor=FFFFFF&transparent=0&bgimage=&gridfreq=20&gridcolor=000000&gridorder=behind&noisefreq=20&noisecolor=000000&noiseorder=behind&characters=5&charheight=&font=fonts/MODERNA_.TTF&textcolor=000000" alt="security code" width="200" height="50" /><br /><label for="security">Security</label><input id="Security_Code_1" name="Security_Code_1" type="text" value="" /><div class="small">Enter the Captcha Security Code shown into the box above.</div><div class="red"><?php if (ValidatedField('homealert','homealert')){if ((strpos((",".ValidatedField("homealert","homealert").","), "," . "15" . ",") !== false || "15" == "")){if (!(false)){ ?>The code you entered does not match the CAPTCHA code<?php }} }?></div></div></fieldset><fieldset><div class="submit"><input class="inputSubmit" type="submit" value="Submit" name="contact_submit"/></div></fieldset></form>
lbunnell124698
No, should have checked that first ;-) Actually none of the validations are working on this page.
Change:
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
and see if the validations start working... do you have a url where I can take a look at the page?
