Issue with redirects after insert/update in 2.0.8
Thread begun 12/21/2010 1:09 pm by Dave Buchholz | Last modified 2/17/2014 6:53 pm by anonymous | 31982 views | 70 replies |
Dave BuchholzBeta Tester
I have gone in to add some new functionality to an existing site on my local test server using DA 2.0.8 (previous pages used 2.0.7) and I am having an issue with the redirect.
This is my insert behaviour code which redirect to details.php?insert=true but instead redirects to details.php?insert=true
// WA Application Builder Insert
if (!($totalRows_rsProduct == 0)) // Trigger
$WA_connection = $connDB;
$WA_table = "tbl_overstock";
$WA_sessionName = "tbl_overstock_id";
$WA_redirectURL = "details.php?insert=true";
  if (
function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "id";
$WA_fieldNamesStr = "productID|title|details|image|price|saleprice|colour|sizing|prodtype|categoryID|subcategoryID|prodtypeID|genderID|sizeID|colorID|tstampinsert|dateinsert|admininsert|publish|sortorder|notes";
$WA_fieldValuesStr = "".$row_rsProduct['productID']  ."" . "|" . "".$row_rsProduct['product']  ."" . "|" . "".((($row_rsProduct['genderID'] != "3")?$row_rsProduct['gender']:'').' '.$row_rsProduct['subcategory'].'<br />'.$row_rsProduct['prodtype']  ."")  ."" . "|" . "".$overstockImage  ."" . "|" . "".((isset($_POST["price"]))?$_POST["price"]:"")  ."" . "|" . "".((isset($_POST["saleprice"]))?$_POST["saleprice"]:"")  ."" . "|" . "".$row_rsProduct['color']  ."" . "|" . "".$row_rsProduct['size']  ."" . "|" . "".$row_rsProduct['prodtype']  ."" . "|" . "".$row_rsProduct['categoryID']  ."" . "|" . "".$row_rsProduct['subcategoryID']  ."" . "|" . "".$row_rsProduct['prodtypeID']  ."" . "|" . "".$row_rsProduct['genderID']  ."" . "|" . "".$row_rsProduct['sizeID']  ."" . "|" . "".$row_rsProduct['colorID']  ."" . "|" . "".time()  ."" . "|" . "".date('Y-m-d', time())  ."" . "|" . "".$_SESSION['adminID']  ."" . "|" . "".((isset($_POST["publish"]))?$_POST["publish"]:"")  ."" . "|" . "".((isset($_POST["sortorder"]))?$_POST["sortorder"]:"")  ."" . "|" . "".((isset($_POST["notes"]))?$_POST["notes"]:"")  ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|',none,NULL|none,none,NULL|',none,''";
$WA_fieldNames = explode("|", $WA_fieldNamesStr);
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
$WA_columns = explode("|", $WA_columnTypesStr);
$WA_connectionDB = $database_connDB;
mysql_select_db($WA_connectionDB, $WA_connection);
  if (!
session_id()) session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id();
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
If I comment out this line:
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
everything works as it should.
This site does not use the framebuilder extension by the way.
It must have the rel2abs function defined somewhere besides the framework builder, since the code shouldn't run if the function rel2abs isn't defined like it is in the framework library.php file.
My guess is that there is an older version of that function that isn't working properly. I'll try to call you in my morning tomorrow to look into it with you.
Ray,
FYI having done a site wide search this morning the only two files in the site where the rel2abs function exists are:
WA_DataAssist/library.php
webassist/caching/CachedResize_Image.php
and of these only the WA_DataAssist/library.php is drawn into the pages where I am having issues.
What happens if you update that file with this version?
The redirect works as expected with the new library file, thanks Ray
p_vouers282571
I have exactly the same problem with the new release. I am still using dw8 so there are no framework issues.
Wish I would have seen the fix with the comment out, I just uninstalled 2.08and put 2.07 back on and it worked fine.
Just to follow this up, if you replace the library file found at WA_DataAssist/library.php with the one that Ray kindly supplied you will find that next time you open the wizard it will be overwritten with the incorrect version.
The answer is to replace the library file found in these locations (Mac only perhaps someone could provide the equivalent windows location) with the new one Ray attached to this thread.
CS4
/Users/USERNAME/Library/Application Support/Adobe/Dreamweaver CS4/en_US/Configuration/shared/WebAssist/ApplicationBuilder/Helpers/library.php
CS5
/Users/USERNAME/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Shared/WebAssist/ApplicationBuilder/Helpers/library.php
This will ensure when you reopen the wizard the correct library file is written to WA_DataAssist/library.php
Hope that helps
neilo
Windows Machines:
C:\Users\YOURUSERNAME\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration\Shared\WebAssist\ApplicationBuilder\Helpers\library.php
C:\Users\YOURUSERNAME\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\Shared\WebAssist\ApplicationBuilder\Helpers\library.php
Andrew Read
Known issue - please. :)
Can this library file and this issue get posted to the known issues for this extension? Again, a sticky here in the forums with a list of the known issues and a link to their fixes would be great. :)
I have made this thread sticky. We'll try to get it updated in the extension soon as well so that these steps won't be necessary.
