Exact Copy of Site
Thread begun 12/21/2010 11:27 am by rob294118 | Last modified 12/21/2010 12:06 pm by Ray Borduin | 1985 views | 3 replies |
rob294118
Exact Copy of Site
I have a client who has 2 domain names. He wants the sites to be the same EXCEPT he wants the Banners to be different.
Do I have to have 2 copies of the site or is there a way to switch the header depending on the URL?
For example: www.deltausimports.com and www.alfafaucets.com
Technicall the answer is both. You would need two copies to comply with our license terms, but you actually probably could switch the header based on the domain name using php.
rob294118
ok. I want to comply with license terms.
How do I edit the footer on just the home page in Powerstore 4? It's much different than Powerstore 3.
The only difference is that you will have to update the file in the theme you are using.
Look for: /webassist/Themes/[yourtheme]/templates/home.dwt.php and that is where you can make the changes for the home page.
