modify css
Thread begun 12/21/2010 10:32 am by segalmedia367166 | Last modified 12/21/2010 5:00 pm by Ray Borduin | 2762 views | 4 replies |
segalmedia367166
modify css
What's the preferred method of modifying my site? I am not going to alter dimensions, but I want to add my own artwork, change background colors on navigation and modify font colors. I am pretty comfortable with css. I am pretty certain that I won't break anything in the layout (or know how to fix if I do).
Logically, I think that modifying the webassist file would work.
Thanks,
Lisa
Follow the steps I outlined in:
showthread.php?t=16199&highlight=supported
Basically you create a new theme and then edit that theme. The files and css are straightforward enough once you know where to look.
segalmedia367166
Thanks Ray,
I did create a new theme, found the files, now I will explore your solution.
Thanks again,
Lisa
segalmedia367166
configurable.css or default_styles.css
Which css file do I modify to ensure that that my style still works with the admin styler and still affects my pages?
the styles in the configurable.css file are what the styler uses. You would have to use these same style names to have them configured in the styler.
