Minimum Order Charge
Thread begun 12/21/2010 3:09 am by info344498 | Last modified 3/10/2022 10:20 am by Ray Borduin | 4561 views | 18 replies |
info344498
What I am trying to do is have the system compare the quantity of an item added to the basket compared to the minimum quantity that is in my database and if it is below this, add a charge on of £20.
Anyone know how to do this?
Thanks in advance.
You could add a column to the cart for MinQty and BelowCharge and set those when you add the item to the cart.
Then create a Calculation:
AddCharge = (([Quantity]<[MinQty])?[BelowCharge]:0)
and then go to the Charges tab and add a charge equal to the Total of the AddCharge column.
Supreme Geek
Minimum Charge Procedure
Go to: WebAssist->eCart->eCart Object
Select the cart object you are using and click "Edit".
Then you will see the Calculations and Charges Tabs.
Supreme Geek
Hey Ray,
I tried to do what you said and now I get a HTTP 500 error. So, I returned the cart to the original calculations. Please see the attached screen shots of what I did. Thanks again for your help!
All the best,
Dale Iannello
You are doing this for the entire order, not per item, so you don't need any custom columns or calculations.
You just need a charge. I have a screenshot of the charge settings I think you could use.Capture.PNG
Supreme Geek
Ray,
I did what you said and "Put" the eCart1_PHP.php file and the Cart file. Attached is my screen shot... Now I get a 503 Service Unavailable error. So, I deleted the charge. Now it's back to normal again. My phone is: 253-988-7944.
Thanks,
Dale
If you provide FTP access to your site then I can take a look.
Supreme Geek
Ray,
I responded awhile ago with my FTP info...any luck?
Thanks,
Dale
I was able to add the charge and upload the file and the page seems to work. I'm not sure why yours didn't.
