Wizard's Wandering's...
Thread begun 12/20/2010 3:06 pm by sunsabbath76401977 | Last modified 1/10/2011 1:50 am by sunsabbath76401977 | 8879 views | 28 replies |
sunsabbath76401977Beta Tester
Hi
Having ago at creating a site log-in.
In tutorial: 02_wizard.swf
Step 4: the above tutorial shows a UserName in the Colum and a Usename in the textfeild.
Trouble is, my wizard doe's not show the same UserName?
I do however get a user first and second name colum and text feild.
SecurityAssist version: 1.1.9
Thanks for reading
Sabby76
Do you have a screen shot of what you see? It sounds like the database isn't correct or the wrong table is selected? But a picture of the problem would help me understand what might be going on.
Uploads
Hi Ray
Uploaded the set-up steps 1 and 3.
Sabby76
Does the column exist in your database? If you click the plus button are you able to add those columns? Your original post was a question about step 4, but you are showing me steps 1 and 3.
Sorry I'm missing what I'm looking at now. Please provide a full description of what you are doing, what you do and don't see and what you are expecting to see. Sorry I'm just getting lost without more details.
Wizard
Hi Ray
The wizard in steps '3, Registartion page options' and '4, User update page options', of the setup tutorial doe's not show a UserName option...
02_wizard.swf
I checked the database and it seems to be missing, how do I add the Username feild?
ps
db snipping attached...
Just use the Email field as the User Name field and you won't have to update the database.
Hi Ray
I do not understand.
The UserEmail is required for the user login process or is it not?
sabby76
Merry Christmas
Hi I ran the config you suggetsed and it all works locally...
Online?
I do know how to connect the DW datbase to the online sever.
Please help:
pizzapal.co.uk/
And goto the login or register pages/
To see the connection fault.
Thanks for reading sabby76
You will have to update the /Connection/ file to have the correct connection information... I don't see errors on your site, so you must have already figured it out.
Configuration
Hi Ray
The security assist configured out the required log-in / register files, I think?
Unfortunetly not everything is working, it was how ever a first attempt and big steps forward were made in uploading and deleting a database online and locally plus configuring the connections file in DW. So I'm happy with the first result. I will run the user log-in security assist wizard again, patching to previous saved version of the site that has not run the security assist config.
Thanks for reading
Sabby76
