Framework Builder Theme Walkthrough
Thread begun 12/20/2010 1:50 pm by Jenny I | Last modified 12/21/2010 12:54 pm by Jenny I | 1745 views | 2 replies |
Jenny I
I have just seen this extension and I am very interested. I just wondered if you could walk me through using it to convert html templates into php includes.
I guess the first step would be to set up my DW site import my html template. How would I then use framwork builder to convert to php include files?
Secondly can this be used with dataassist wizard. The reason I ask is because when you use the wizrd it always asks to select a template. I would like to use Framework builder to create php includes then use for dataassist wizard instead id DW template is this possible?
You can watch the feature tour to see an example of how to update from a dreamweaver template to a webassist theme: ?lid=websitebuilders
It talks about themes in the final minute of that video and shows an example of what you can do.
DataAssist, you would probably want to keep the template field blank and use a plugin or applied theme from framework builder after the wizard has run.
Jenny I
Hi Ray
I have just pruchased so I will give it a try. Will post back if I need more help.
Many Thanks
