Unable to edit the map in Dreamweaver CS3
Thread begun 12/20/2010 3:54 am by frenchboi419631 | Last modified 12/20/2010 1:04 pm by Jason Byrnes | 2152 views | 3 replies |
frenchboi419631
I have been using the google maps fine since our last encounter, but sometimes when i click on the map to edit it, nothing will happen, i think it has something to do with the positioning of the code: </div>
</div>
<p>
<p></p>
<div id="wagmp_map_" style="width: 600px; height: 600px;"></div>
<p>
</div>
</div>
</div>
And is there other ways to edit the map without clicking on it.
Thanks for your help
p.s can you create multiple maps on one website.
could be something caused by the unclosed <p> tags. try removing the empty and unclosed <p> tags to see if that fixes anything.
Yes, you can add multiple maps to your site. you can also add multiple maps to the same page.
frenchboi419631
Yes
Yes that has worked, and once again thankyou for your speedy reply, this is the best forum i have been on.
p.s when adding multiple maps is a new api key required?
excellent, glad to hear it is working.
a new api key is only required if the map will be served on a new domain.
