Powerstore 3.01 Virgin Install--Can't Create database.
Hi I am using a straight-out-of-the-zip install of Powerstore 3.01 in a subdirectory off of / called "store." I have not tampered with files in any way.
The server checks out completely (step 1). I enter localhost, databasename, root, my password. It goes to step 3.
When I get to step 3, the install script is unable to store the Admin credentials in the database...and no wonder...no database has been created (when I connect through phpMyAdmin, there is no database created).
The "Connections" directory exists and the PowerStoreConnection.php file has the following:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_PowerStoreConnection = "@@server@@";
$database_PowerStoreConnection = "@@database@@";
$username_PowerStoreConnection = "@@username@@";
$password_PowerStoreConnection = "@@password@@";
$PowerStoreConnection = mysql_pconnect($hostname_PowerStoreConnection, $username_PowerStoreConnection, $password_PowerStoreConnection) or trigger_error(mysql_error(),E_USER_ERROR);
Just to clarify, the variables are the actual credentials I need to log in to the database, not the variables listed here. But the tables are never built. I tried it with the database already present and that was no help. As root I have full access and all rights as do 2 other users I created. No one can login from the install script and the install script won't create the database.
I have been testing session variables and they are set. I have error-logging turned on and no php errors are being pitched.
Any ideas???
