Universal Email 4 with Godaddy
Thread begun 12/16/2010 9:42 am by sridigi392785 | Last modified 2/22/2011 9:55 am by Jason Byrnes | 7271 views | 6 replies |
sridigi392785
I hosted a site on GoDaddy, Linux plan with php 5
smtp server: smtpout.asia.secureserver.net
port: 25
additional parameters checked
goto page has been set
from address is valid email id
still emails are not coming in
Could any one help who overcame this problem before
have you tried using relay-hosting.secureserver.net as the SMTP server?
sridigi392785
tried now
i have tried as per your suggestion now but no use of it
i used the port as 25 is it ok?
yes, port 25 using relay-hosting.secureserver.net should do the trick.
you should contact GoDaddy to have them look in the smtp servers error logs to see why the email is not being relayed.
dsnoyes418343
Is this set up in the form itself or is it a setting in the GoDaddy control panel someplace?
dsnoyes418343
actually, I found the SMTP server setting - where would the port be defined?
the port setting is in the same place as the SMTP server setting in the universal email wizard.
