javascript error when inserting UEmail in CS3
Thread begun 12/16/2010 8:18 am by tmcbinc99963 | Last modified 12/16/2010 11:39 am by Jason Byrnes | 2404 views | 3 replies |
tmcbinc99963
Saw the previous posts on emptying the cache et al. Using Mac osx 10.4 and trying to follow your instructions but can't locate the correct file. Application support > adobe > don't have a Dreamweaver 9 or CS 4 directory; only 'Adobe creative Suite 3 Design Premium', 'Adobe Asset services CS3', 'Adobe PCD', among other unrelated directories. I've opened each of these files, as well as others with no luck. Search also doesn't find files you mention in your instructions. Where are these files located in osx 10.4 CS3?
Have also tried uninstall/reinstall; both not replacing, then replacing existing files; same error.
Make sure you are going to the correct library folder.
there is a library folder at the root of the Macintosh hard drive, this is not the one you want to look in.
instead go to:
Macintosh HD: Users: <your user name>: library: Application Support: Adobe: Dreamweaver 9: configuration
where <your user name> is the user name you login to the computer with.
tmcbinc99963
Problem solved
My fault; missed the part about the 'users' library.
no worries.
