Manage Relational Table - Working Tutorial?
Thread begun 12/16/2010 7:44 am by Andrew Read | Last modified 5/10/2011 8:42 am by Jason Byrnes | 14195 views | 21 replies |
Andrew Read
Hello,
Just wondering if there is a working tutorial for the Manage Relational Table (MRT) Server Behaviour? I have done some reading from the site and can't quite get it working. None of my checked items get inserted into the binding table.
I have three tables (Contracts, Venues, Link_CV.)
Contracts - contains contract information
Venues - contains venue information
Link CV - has unique ID and two fields "venue_ID" and "Contract_ID"
1. On insert page I have removed redirect URL from DataAssist insert behaviour.
2. I have created a looping checkbox set using a database query that retrieves all of the venues.
<?php $setRows=0; ?><?php do { ?>
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
    while(
$RepeatSelectionCounter_1_IterationsRemaining--){
        if(
$RepeatSelectionCounterBasedLooping_1 || $row_getVenues){
          <div id="repeatBox">
            <label>
              <input type="hidden" name="WADA_RepeatID_venue_id_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_venue_id_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_getVenues["venue_id"]; ?>" />
              <input <?php if (!(strcmp($row_getVenues['venue_id'],WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, $row_getVenues['venue_id'])))) {echo "checked=\"checked\"";} ?> type="checkbox" name="venueCheck[<?php echo $row_getVenues['venue_id']; ?>]_<?php echo $RepeatSelectionCounter_1; ?>" id="venueCheck_<?php echo $row_getVenues['venue_id']; ?>_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_getVenues['venue_id']; ?>"/>
              <?php echo $row_getVenues['venue_short']; ?></label>
          </div>
          <?php $setRows++; echo $setRows; if ($setRows == 3) { echo "<br/>"; $setRows=0; }?>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
No records match your request.
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
            if(!
$row_getVenues && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_getVenues = mysql_fetch_assoc($getVenues);
$RepeatSelectionCounter_1++;
// RepeatSelectionCounter_1 End Loop
          <?php } while ($row_getVenues = mysql_fetch_assoc($getVenues)); ?>
3. added MRT behaviour to page using:
WIZZARD PAGE 1
Trigger - Button:Insert Pressed
DB connection
relational table set to link table
goto set to results page
WIZZARD PAGE 2
Foreign key column - contractID from link table
data type - numeric
key value - set to created insert record id from contract table (WADAnsertRecordID)
WIZZARD PAGE 3
foreign key column - linked table venue id
data type - numeric
options form field - wada repeat id venue id in repeat selection
WIZZARD PAGE 4
no changes made
Something is wrong - maybe with the name or ids given to my looping checkboxes? Any help would be appreciated - and when this is working I will make a step by step guide for this as nobody else has done it yet. :)
Thanks.
1) the name of the checkbox will create issues:
should be:
name="venueCheck_<?php echo $RepeatSelectionCounter_1; ?>"
2) In step three, use the checkbox form element instead of the wada repeat id venue id hidden form element.
Andrew Read
OK, I have started from scratch and now I am getting an error that the contract ID in the linked table can not be null - which it is not supposed to be.
It seems that it is not getting the value for the inserted record primary key from WADAInsertRecordID
This must be relating to the order that things are happening - the data for the primary table (contracts) is being inserted into the database, but this error pops up when trying to enter the data into the relational (adjoining) table.
Should the insert record primary key be available at this point for the MRT to use?
I have no way of knowing with out seeing the code.
please compress your php file into a zip archive and attach it to your reply, once i have a copy o the page and can see the code, I will have an idea of where the problem may be.
Andrew Read
Unfortunately I use WinRAR - so it is a RAR file and can't be uploaded - maybe you could add that extension.
Here is a link to it: link
I'm on a mac and cannot open rar files.
Win rar can be used to save the archive as a zip:
zip_file.htm
Andrew Read
  I'm on a mac
Egad! No wonder these extensions have issues on the PCs... you're a Mac shop. :D
Here ya go.
we test equally on Macintosh and PC.
The issue is that you have bound the cv_link_contractID column to the WADAInsertRecordID form element. you will need to use the WADA_Insert_contracts session variable instead.
the WADA_Insert_contracts session variable is created by the insert record server behavior to hold the ID of the record that it creates.
Andrew Read
I should hope so.. but that was a joke - notice that smiley... :D
Thank you for the help - it seems to be working now. On to the update DataAssist form, which should be a piece of cake now... ;)
However, the DataAssist delete form - how does one get it to delete all of the records pertaining to the link table when one deletes the main item?
Andrew Read
Also, on my insert form when I insert a second (new) record it has the checkboxes from the last record pre-selected - where is this coming from and how can I have the checkboxes default to blank?
Thank you.
