Looking for step by step tutorial.....
Thread begun 12/15/2010 10:12 am by tone397472 | Last modified 1/26/2011 1:50 pm by Ray Borduin | 10896 views | 37 replies |
tone397472
Looking for a step by step tutorial to make a simple log in registration administration system.
I'm not interested in a downloadable sql I can make my own database, but need to know how the database is set up to work best with the extensions and why.
The sql from the website is based on a web shop and I only need the login registration administrator part.
I did the Blue Sky tutorial, but this leads not to a simple system I'm looking for.
Of course including encrypting, User Level Authentication and Cookies treatment.
Hope it is somewhere!
Or please answer the first question: If I want a registration-page with:
First name:
Family name:
Email:
Password:
What is the best set up for the database when trying to accomplish this with WA extensions?! And keeping in mind that there will be administrator excess and users excess?
The tutorials available on the security assist support page walk through creating Password encryption and user level authentication.
if you want to create your own database for both user level authentication and password encryption, your database structure would contain 2 tables, the vbasic structure would look like:
users:
userID - Integer, PrimaryKey
userUserLevelID - integer, Foreign Key - relates to userlevel.userLevelID
userEmail - varchar(25) - used as the username column
userPassword - varchar(40) - Password column, needs to allow 40 characters for the SHA1 encryption
you can add other column like userFirstName and userlastName
userlevel:
userLevelID - integer, primary key
userLevel - varchar(25).
if the tutorials are not ending in the simple system you are looking for, perhaps it would be helpful if you described what precisely is the issue you are having. all of the available tutorials ore on the security assist support page.
tone397472
thanks!
Thanks Jason! I'm going to try it with this set up. I was under the impression that I only needed 1 table, maybe that's where it went wrong.
you're welcome.
tone397472
Hi, Can you please help me with the individual steps in the wizards from Data Assist and Security Assist to make a log in system with administrator.
I have been reading all tutorials incl. the Blue Sky one, but can't get my head around it, because the tutorials are to specific to extract the information out of it I need.
I already got the database set up like Jason explained me in a earlier post.
users:
userlevel:
I can make it with Dream Weavers wizard and server behaviors, but I'm looking for a simple one time explanation to work with the Dynamic Suite.
Please some help
Thanks! David
You would run through the SecurityAssist wizard to create the front end removing the access group field from the registration and user update pages, then you would update the login page so that the userUserLevelID is also stored in the session.
Then you could limit access in the secruity assist rules to check that session variable to give specific privilages to specific groups.
Then use DataAssist to create a set of insert/update pages to allow the admin to set the user group from a list using the userlevel table to populate the select list where you choose the userid.
tone397472
Hi, Can you please give me further details concerning the database?! For example what fields need a default NULL, INDEX or Auto Increment.
Don't blame me for stupid questions it's the first time I'm trying to use the extensions.
And I really don't understand this in your explanation:
Can you please specify the first steps I make in the security assist wizard with this database setup?!
Why is in the table users the 2th field named userUserlevelID(the foreign key of userlevelID and not userlevelID like his primary key in the table userlevel?!
Thanks! David
By that I mean that you would run the wizard twice, once for admin and once for general users.
The portion not for admin wouldn't expose the access group field, since you wouldn't want people to be able to choose their access group as they register.
The column names are uniquely named to prevent confusion when referring to them later. They could be the same, really the database design can be whatever you want, but making sure each column is uniquely named we just avoid having to talk about ambiguous column names in joined queries.
tone397472
Thanks! Can I use Data assist for the administrator part? And login as administrator to get there from the normal login page? And not run the Security Assist wizard twice?!
Security Assist you can run once to create the login page and then protect the admin pages accordingly. You can share a login page with the front end and differentiate based on group.
