Dot replace with comma before inserting
Thread begun 12/15/2010 6:05 am by turbo.sarajevo416658 | Last modified 12/15/2010 10:31 am by Jason Byrnes | 6251 views | 3 replies |
i need to replace commas on several fields before inserting into database. I need users to enter numbers with commas as decimal separator but convert those commas into dots before inserting. How can I do this in multiple insert and single insert behavior from dataassist?
in the data assist insert record behavior, when you bind the column to a form element, the code in the value field will look like:
<?php echo((isset($_POST["textfield"]))?$_POST["textfield"]:""?>
you will need to use the php str_replace function to convert the comma to a decimal:
<?php echo((isset($_POST["textfield"]))?str_replace(",""."$_POST["textfield"]):""?>
function.str-replace.php
Great, thank you very much
you're welcome.
