UE4, redirect and Framework builder error
Thread begun 12/15/2010 5:10 am by Jediha | Last modified 12/15/2010 10:34 am by Jason Byrnes | 2858 views | 3 replies |
Jediha
As soon as i use the dynamic plugin and include the page on which I've a mailform with UE applied, the form doesn't work!
Somehow the redirect doesn't go well, because I end up in the root, and NO mail is sent.
When i open the page with the mailform directly, the formcontent is mailed and the page is redirected OK.
The form has no action applied. The redirectpage is on the same level as the formpage and hostpage. There are no other scripts loaded.
I've seen a simmilar thread, but does not work/apply to this situation.
Please advice!
Thanx!
Hans
the forms action should be set to post to the framework builder page, do not eave the action empty.
also make sure that the trigger for universal email does not use the currant page submit trigger, but uses the button submit pressed trigger instead.
if your are still having a problem, it would help to send a copy of both pages in a zip archive and a link where i can see the issue.
Jediha
Thanks Jason,
That worked. Mayby good to make this as a sidenote in the examples/tutorials. Because in all the UE resourses it says to leave the action empty or give it a php SELF... tag.
So in combination with Framework Builder it is slightly different.
Great extensions by the way, once you get to know the ins and outs. (and the hacks..:-))
Hans
Glad to hear it is working.
please submit documentation requests to the documentation teamdirectly using the following feedback form:
feedback.php?type=docs
