Adding fields to registration form
Thread begun 12/14/2010 2:07 pm by mrobben375515 | Last modified 12/15/2010 10:35 am by Jason Byrnes | 2124 views | 3 replies |
mrobben375515
Hi, I would like to add a couple fields to the registration page. I would just create a new form but I like the fact that it registers the IP address and a few other things. Is there a way I can easily add required fields for name, address, etc.? Maybe with CSS form builder?
you would need to add you new form fields to the registration form by going to Insert -> Form - > Text Field.
then update the Server Validations server behavior in the server behaviors window to add the required validation to the new form fields.
you also need to add new columns to the users table to hold the values of the new form fields.
you then need to update the insert record server behavior to bind the new database columns to the new form fields that where added.
mrobben375515
perfect, thank you
you're welcome.
