Error mesage
Thread begun 12/14/2010 6:59 am by cnmpat323745 | Last modified 12/15/2010 11:13 am by Jason Byrnes | 2939 views | 5 replies |
cnmpat323745
Error mesage
I get this message periodically when I am filling in a table. I do not know what it means. Could someone please explain it and what to do about it.
Usually I keep fiddling and eventually accomplish what I am doing.
Data too long for column 'HistoryValue' at row 1
Pat
the error means that the value being stored in the HistoryValue column is to long.
you can try changing the HistoryValue column type in the mysql database to longtext instead of text.
cnmpat323745
Text Error
Where would I find this ?
in the code that I put onto my PHP page. Not sure where the database file is to which you refer.
you would need to edit the database structure in the mysql server. It is not a file.
cnmpat323745
error message
I have no idea how to do that.
I am not familiar with how to change a database structure.
isn't there another way/easier way to deal with this issue ?
the line isn't that long, shorter than the space allotted.
It seems like an odd error message, as sometimes it works, and sometimes not.
I know it will be frustrating to others wishing to use their page.
no, there is not another of dealing with the isuse. You would need to modify the database structure.
your host should offer a control panel that will give access to the database using PHPMyAdmin. this should allow you to change the column type for the content history column in the database.
