PowerStore Links Not Working
Thread begun 6/19/2009 4:34 pm by paputxi | Last modified 6/19/2009 5:55 pm by paputxi | 23444 views | 2 replies |
paputxi
I am having a problem getting any of the links to work on either the main page or the Admin back-end after logging in. I updated the WA_Globals.php and localhost.php files, per the directions, before uploading all the files to my website. The only parameters I changed in the WA_Globals.php were the first set of parameters starting with WAGLOBAL_Root_URL, site address, etc, and leaving the local and remote root parameter set to "/". I also change the WAGLOBAL_Admin_UserName and WAGLOBAL_Admin_Password parameters as the default values did not seem to work either. I left all the other parameters alone for now as I just want to test out the package.
Note: I do have this web setup as a subdomain or folder off the main domain, that is, it is something like powerstore. I was able to upload all the files into this area just fine and then bring up the main home page and Admin home page just fine in my browser. Perhaps having this in a subdomain or folder is causing the problem, but I can't figure out how to resolve it. Seems to be a relative linkage reference problem.
I tried various configurations in changing the WAGLOBAL_remoteRoot from "/" to "/powerstore/", "www.mydomain.com", "www.mydomain.com/powerstore" and "/www.mydomain.com/powerstore/", etc., but no luck.
Any suggestions would be greatly appreciated.
Neil Beadle
Have you tried "http://mydomain.com/powerstore/"
I believe the path needs to always end in a "/" and also needs to contain the http://
paputxi
Thanks for your reply, Neil. Thinking about your response made me observe the URL more closely when I clicked the other links. So, I tried setting WAGLOBAL_localRoot = "/powerstore/" (rather than the WAGLOBAL_remoteRoot parameter, which I set back to "/") and that worked. Problem solved!
