Can't use a php IF test in UniversalEMail?
Thread begun 12/13/2010 4:04 pm by SaladoGuy | Last modified 12/16/2010 6:45 am by Jason Byrnes | 5042 views | 8 replies |
SaladoGuyBeta Tester
Hello,
For almost a week I've been working on this simple problem and can't figure it out ...
On this website that I'm building (done with eCart and other WA extentions), customers buy classes. It may be a one day class or a multi-day class. In the email confirmation receipt it is important for the customer to see the dates of the class they just bought so they know when to show up :-)
It's easy enough to print both dates:
<?php //echo $eCart1->DisplayInfo("Date"); . " - " . $eCart1->DisplayInfo("Through"); ?>
( FYI $eCart1->DisplayInfo("Through") is a cart attribute that I created and it does work, perfectly, everywhere else on the site )
I can also assign those dates to variables and format them nicely:
$bdate = $eCart1->DisplayInfo("Date");
$edate = $eCart1->DisplayInfo("Through");
print date('l F jS, Y', strtotime($bdate));
And all of that works great both on the site pages and in the confirmation email. The email is a UE4 object, but I believe it was created as part of the eCart checkout wizard.
With these functions I can get a nice looking date such as:
Thursday December 21st, 2023
through —
Fri., Dec. 22nd
The breakdown occurs on one-day classes. I don't want to print 2 dates on the one day classes, it looks bad and confuses the customers.
On the php web pages this is is to do, I simply put the "through -" and the second date inside an if statement and only display them if the start date and end dates don't match:
<?php //echo $eCart1->DisplayInfo("Date"); . " - " . <?php echo $eCart1->DisplayInfo("Through"); ?>
if ($bdate != $edate) { // Show if date doens't match
print "<br /><em>&nbsp;&nbsp; through &nbsp; &mdash;</em><br />" . date('D., M. jS', strtotime($edate));
//print "&nbsp;-&nbsp;to&nbsp;-&nbsp;" . date('D., M. jS', strtotime($edate));
} // Show if date doens't match
However, not matter what I try, I cannot get an if statement to work correctly in an email.
I've tried all kinds of things, my last try was:
<?php if ($bdate != $edate) { echo "does not match"; }?>
<?php if ($bdate == $edate) { echo "does match"; }?>
<?php if ($bdate != $edate) { print "does not match"; }?>
<?php if ($bdate == $edate) { print "does match"; }?>
<!--Show if date doens't match-->
<?php if ($eCart1->DisplayInfo("Date") != $eCart1->DisplayInfo("Through")) { "<br /><em>&nbsp;&nbsp; through &nbsp; &mdash;</em><br />" . date('D., M. jS', strtotime($edate)); }?>
<?php // alternate print line:// print "&nbsp;-&nbsp;to&nbsp;-&nbsp;" . date('D., M. jS', strtotime($edate)); ?>
Does anyone know how to do this in an email?
Here's the relevant files in case it helps (attached) ....
If anything about that post wasn't clear or I need to explain it better, please let me know.
look at the lines that do work, they are not using an echo, but instead, they are applying the text to the $MailBody variable:
$MailBody = $MailBody . date('D., M. jS', strtotime($edate));
you need to do the same with your if statement. instead of:
use:
if ($bdate != $edate) { $MailBody = $MailBody . "does not match"; }
use:
Thanks! That was it.
CraigRBeta Tester
Hooray!
I'm glad I picked up this thread, I was experiencing a similar problem
showthread.php?t=17722
Can someone at WA confirm, that if you have an 'if' statement in the code, that the 'edit in dreamweaver' option for UE4 doesn't give you the correct result.
Can I also assume that it would be a bad idea to edit the email via the server behavior interface once these changes have been hand coded ?
FYI my issue now appears to be resolved, the only other problem I had was that a value from a recordset want being included in the email, but this was fixed by moving the server behavior code block to below the recordset block.
it all depends on how you code the if statement.
coding the if statement like this will not work correctly:
if("this" != "that") {
    echo((isset(
$_POST["textfield"]))?$_POST["textfield"]:"");
} else {
    echo((isset(
$_POST["textfield2"]))?$_POST["textfield2"]:"");
however, coding the if statement like this will:
<?php if("this" != "that") { ?>
echo((isset($_POST["textfield"]))?$_POST["textfield"]:""); ?>
} else { ?>
echo((isset($_POST["textfield2"]))?$_POST["textfield2"]:""); ?>
the key is that universal email will transalate code in the following form:
<?php echo((isset($_POST["textfield"]))?$_POST["textfield"]:""); ?>
$MailBody = $MailBody . ((isset($_POST["textfield"]))?$_POST["textfield"]:"");
but when it is literally surrounded in the if statement, it does not translate properly.
CraigRBeta Tester
thanks Jason.
For now, I edited the waue_confirm_1.php manually to get the desired result
if i revisit this page via the interface and use dreamweaver edit, i assume the template is re-created from the waue_confirm_1.php in the correct format
it should be, yes.
