confirm.php from checkout wizard seems to just reload
Thread begun 12/13/2010 12:19 pm by Armen | Last modified 12/14/2010 5:16 pm by Jason Byrnes | 6340 views | 14 replies |
Armen
DW CS5 / PHP / MySQL / eCart 5.0.3
I created all forms using the checkout wizard. However, when the 'Submit Order' button is pressed on the conform.php page, the page seems to just reload as opposed to going to checkout-success.php or checkout-failure.php.
here is a link to the site in question: index.php
Any ideas as to what's causing this?
most likely a php error is occurring.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
Armen
I've added the code. Not sure what I need to do next...
when i view source of the confirm page, the forms action shows a php error:
<form name="ecart_checkout_form" action="
Notice: Undefined index: ../PHP_SELF in /hsphere/local/home/c2808470/testing-server.com/shop/confirm.php on line 684
" method="post">
the code for the form tag should be:
<form name="ecart_checkout_form"  action="<?php echo htmlentities($_SERVER["PHP_SELF"]); ?>" method="post">
Armen
I changed the code as per your suggestion. However, the issue still persists.
what payment gateway are you using?
paypal standard? or paypal payments pro?
Armen
Not using PayPal. I'm using AuthorizeNet AIM local checkout.
Armen
Having the same issue with a second, more simple cart on the same server: donate.php
I didn't change anything on the pages created by the WebAssist Checkout Wizard.
Armen
Is there anything I can provide you to try and expedite the solution to the checkout wizard not working?
please send a copy of the confirm page in a zip archive.
